Re: Super M won't restart
Posted by charlie M on June 20, 2010 at 09:02:22 from (65.37.31.217):
In Reply to: Re: Super M won't restart posted by gatorhide on June 19, 2010 at 18:44:54:
Does your motor turn by hand - if not then either starter is jammed against the ring gear or you are locked in to gears in the transmission.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
