Re: Super M won't restart
Posted by Brownie 450 on June 21, 2010 at 04:48:49 from (66.43.241.95):
In Reply to: Super M won't restart posted by gatorhide on June 19, 2010 at 17:39:16:
State has a good point. Don't remember if the SH has batt. under seat or not. The grounds at the back of batt. boxes had a bad reputation for rust/ corrosion. Check ground connections.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
