Posted by El Toro on June 21, 2010 at 17:14:20 from (74.103.74.58):
In Reply to: H mag no spark posted by Zachary Hoyt on June 21, 2010 at 15:04:04:
Those magnets are what create's your spark from a mag when they pass by the coil. If they don't have much magnetism that may be your no start problem. You can convert your mag to a distributor to get the tractor home. You would need to install an auto type coil. Then install an ignition switch & run battery voltage to the switch and then to the coil and connect the wire to the + terminal on the coil if your battery is - negative grounded. Run another wire to your points from the coil. Disconnect the old coil wire on the mag at the points. Then see if you engine will start. Some owner's leave it that way or you can have the mag rebuilt and they will remagnetize your old magnets. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
