Re: Starter noise
Posted by Brownie 450 on June 22, 2010 at 06:36:15 from (66.43.241.95):
In Reply to: Starter noise posted by Dave H (MI) on June 21, 2010 at 09:00:43:
We had starter trouble on our Cat 112 motor grader. Had to get a new gear at the repair shop, & they said that it was probably a 12-volt conversion--it wasn't, but we had been using jumper cables off the pickup. Anyway, he said that 6-volt inertia type starters [A,C,H,M type] used on 12-volt were spinning too fast to get the drive gear engaged with the ring gear--gears clash. Anyway, we always use 6-volts on our A, SC, H's & never have trouble. The SMTA is the exception.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
