Posted by riverbend on June 27, 2010 at 11:10:52 from (70.101.157.10):
I have a 1940 H with a 6V generator and voltage regulator, positive ground system. Nothing is connected to the 'L' terminal of the VR.
The system will not charge the battery.
I went through the usual votage regulator checks. When I connected the 'ARM' terminal to the 'Bat' terminal the ammeter showed a 15A discharge rather than staying close to zero or going positive. The rest of the checks had no effect.
I had put new brushes in the generator recently. If I connect the field terminal to the generator case and hook the negative battery terminal to the 'ARM' terminal and the positive battery terminal to the generator case, the generator spins fairly slowly. When I remove the wire from the field terminal, it speeds up.
I substituted a new 6V, + gnd, VR and it did not charge either.
Any idea what to check next ? Or even better, what's wrong ?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
