Re: Charging problem, what next ? - solved
Posted by riverbend on June 29, 2010 at 03:20:02 from (74.46.191.45):
In Reply to: Charging problem, what next ? posted by riverbend on June 27, 2010 at 11:10:52:
The armature in the generator was bad. The generator would motor, but slowly.
New armature, a bearing, a bushing, $75, and it should be good for another 20 years.
Greg
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
