Adding a hydraulic circuit to a 300U
Posted by ChrisNH on June 27, 2010 at 18:04:06 from (75.67.227.170):
I have a 55 IH300U that came stock with one hydra-touch circuit which lifts the fast-hitch. Wanting to add another, I picked up a hydra-touch control valve but the block underneath the valves (check valve I think) has the hose ports right up against the tractor body so close it won't bolt on. I am trying to put it on the empty valve port on the right hand of the driver's seat. Is there a spacer port or maybe a different check valve with hose ports on the bottom I need? I would bolt it onto the existing valve, but it has a hard hydraulic line running from it to another block between it and the tractor. Is there a way I can add it there?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
