Cub Radiator bolt torque specs
Posted by Lurch. on June 28, 2010 at 21:38:13 from (173.87.221.80):
The radiator base gasket eroded on my cub and I have gotten a new cork gasket. I have head bolt specs at 45lbs. But was wondering about the 5/16 inch bolts from the radiator to the frame. What would be the correct tightness and should I use a torque pattern or sequence to tighten the bolts?? Also, is silicone sealer acceptable for this application?? Is antifreeze safe to use or is that causing these gasket problems???
