Re: firing order on a farmall cub.
Posted by The Red on June 03, 2000 at 06:14:41 from (12.75.197.87):
In Reply to: firing order on a farmall cub. posted by Tex on June 03, 2000 at 06:07:21:
Tex you need to get #1 piston on TDC. Make sure you are on the compression stroke and not between exhaust and intake stroke. Otherwise your cub will sound like a JD 40.
Once you have established that, look at the rotor position. That post will be #1. Then in clockwise order 3,4,2.
Post A Followup
: Re: Re: firing order on a farmall cub.
