Re: Re: firing order on a farmall cub.
Posted by The Red. In addition on June 03, 2000 at 07:07:42 from (12.75.197.59):
In Reply to: Re: firing order on a farmall cub. posted by The Red on June 03, 2000 at 06:14:41:
There is a chance you might also be out of time. Once you have #1 on compression TDC, note the rotor position, and you might have to adjust the distributor base so the points are just opening so your timing will be close to TDC.
Post A Followup
: Re: Re: Re: firing order on a farmall cub.
