Re: Farmall M carb leaking gas like a fuacet
Posted by RustyFarmall on June 30, 2010 at 06:38:37 from (209.152.78.140):
In Reply to: Re: Farmall M carb leaking gas like a fuacet posted by Awelsh on June 29, 2010 at 23:02:59:
Never, I repeat never, test a float in HOT water.
The heat will cause the air inside the float to expand, and those solder joints will just plain blow wide open.
If the float is defective and has a hole in it, the air bubbles will show up just as well using COLD water.
Your carburetor most likely can be cured with a simple, basic gasket set and a new needle valve and seat. About $10.
