rustred said: (quoted from post at 20:41:00 06/29/10) as mentioned float may be toast. best bet is to just remove carb and give it a cleaning by soaking it in carb cleaner,and blowing out good with air. could possibly be debri stuck in needle and seat, or just worn out, or even float hanging up. check the pin that holds float in place. float level setting i believe is 1 5/16 . if you have it all apart best to put a kit in. but thats some thing to look for.
I tested float in hot water per Farmall web site and it did not bubble to indicate a leak so I can't figure out what is causing my gusher, I'm no rocket scientist but this Is not making sense to me. Do yo think it's as simple as just a carb kit with new gaskets and washers?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
