Re: H mag is giving me fits
Posted by Janicholson on July 01, 2010 at 20:11:54 from (64.61.211.174):
In Reply to: H mag is giving me fits posted by Zachary Hoyt on July 01, 2010 at 17:58:48:
Make a card board disk about 2.5" diameter.
in the center make a hole that the rotor shaft will slip through.
Tape this to the mag body so it will not turn.
Put the rotor on.
slowly turn the engine and listen for the mag impulse click. when it does, mark the center of the rotor tip location on the card board. Do this three more times, and you will have an exact location for rotor for the firing of the mag.
Now take the cap and put it up to the cardboard and determine where it is in relation to the marks (line up the screw holes!)
It must point to the plug tower!
I bet this works. Jim
