Is the rotor inline with the tower when the mag trips iy must not or your engine would fire and run, Remove the cap and look where the rotor p[oints when the mag impulses rotor must line with the cap so the fire goes to the plug or else the fire will come either too soon or too late as the mag impulses on TDC, You cant get fire to the plug if the rotor isnt lined you correct.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
