Re: 140 with a Woods L59 - reality check??
Posted by Pete in PA on June 03, 2000 at 19:15:55 from (64.41.33.132):
In Reply to: 140 with a Woods L59 - reality check?? posted by Pete in PA on June 02, 2000 at 13:10:48:
Aha!! THanks fellas. I knew I could count on you!!
Post A Followup
: Re: Re: 140 with a Woods L59 - reality check??
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
