3 pt will not go down: Maybe the unload valve is stuck. Check with engine running, raise the hitch and at same time pull the remote lever. If the hitch raises, you have dirt in the unload valve. This valve is under the seat and you remove the large plug for access. One trick, loosen the large plug, unload valve, 2 turns and start the engine, the hitch should raise if the valve is stuck. It has a small hole in the valve and just blow the dirt out with air. Replace the O-rings with new ones. OR There is a cover on the right side, in front of the rock-shaft. Remove and check if the spool valve moves with the position lever. Make sure the draft lever is down. It has a long spring, with a rod, may be that spring is not unhook. Bernard le mécano Québec Canada
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
