IH 574 - 3pt. Stuck In UP position!!
Posted by RichieMagoo on July 02, 2010 at 14:21:26 from (64.130.185.101):
Hey Guys,
I have a 574 with the usual parking brake goop in the hydraulics problem. I"ve had to change the hydraulic filter after every hour of use, to keep the hydraulics functioning.
Recently, when it was time for a filter change, I drained the fluid and flushed the system with some diesel. Tractor worked great after that! I moved 19 rolls of hay and it was still going strong (a record!)- when I went to drop off the 20th roll, I moved the lever to lower the 3pt. - but the 3 pt. wouldn"t go down.
It"s still sitting out there with the 1500 lb. roll up in the air...it"s been there for over 48 hours!
What gives? Any ideas????
HELP!!!
