Re: 454 oil usage
Posted by Janicholson on July 04, 2010 at 16:57:04 from (64.61.211.84):
In Reply to: 454 oil usage posted by Ranch Hand on July 04, 2010 at 15:16:28:
The best fix is a sleeve/Piston/and gasket rebuild. Checking engine bearings for wear as well.
It can be done in the tractor, or out in a shop.
If it were mine, and I knew it was just getting worse, and not a sudden onset thing, I would just do as above. If I knew it had been sitting for a long time, I would put a tablespoon of auto trans oil into each cylinder and let it sit for 3 days then give it a try. It will smoke for a few minutes from the oil, then should either be better, or still require an engine kit. Jim
