Re: another H clutch question
Posted by Seth Boyer on July 06, 2010 at 16:56:25 from (72.161.84.54):
In Reply to: another H clutch question posted by c1802362 on July 06, 2010 at 16:01:53:
I'm not 100% sure on this because I have never tried, but I don't believe you can remove the flywheel in the same way you can replace the clutch through the bottom. You are correct that the 4 bolts will allow you to remove it, but the tractor must be split to actually get the flywheel out.
