Posted by c1802362 on July 06, 2010 at 16:01:53 from (72.195.142.179):
In a previous post i asked for advice as to getting the clutch off the flywheel - thanks - that part is done
Now the issue is the damaged OD race of the pilot bearing is stuck in the flywheel bore. I can't pry it out, and it seems the only way to get at it is to remove the flywheel and press out the race.
So, there are 4 bolts with a washer bridging each two bolts on the flywheel. Is the best way to take off the flywheel to remove the 4 bolts and remove the flywheel through the bottom of the tractor?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
