There are two other options for removing the pilot bearing if you have access to a welder.
The first (and in my opinion best method or the two) is to find a nut with an outside diameter close to that of the inside diameter of the old pilot bearing. Install a bolt in the nut and weld the nut to the remains of the pilot bearing, be sure to clip the ground clamp to the bolt. To remove simply wind the bolt in and it'll push out the nut and pilot bearing.
The second (which will only work if you have only the outer race left) is to weld several beads (in short segments) on the bearing surface of the race and allow it to cool. This will shrink the race and allow it to be withdrawn easily. Your best bet is to clip the ground clamp to one of the bolts which holds the pressure plate to the flywheel.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
