Which washers are you talking about, just a guess , the ones between knife and knotter frame. If that is the case, the reason you need so many washers is that your disks are timed late due to wear. It is a heck of a job to get them back where they belong unless you go the later style disk drive shaft which has a tapered shaft with lock nuts and you can set the distance between knotch and knotter frame any place you want. That was one real big improvement on later knotters. Many more changes also, another big one is the twine end retainer spring. Helps a lot. 80 percent is not very good which I know you are aware of.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
