Re: *SUPER -M- RUNS AGAIN*
Posted by Janicholson on July 08, 2010 at 06:02:16 from (199.17.6.23):
In Reply to: Re: *SUPER -M- RUNS AGAIN* posted by gatorhide on July 07, 2010 at 21:31:07:
Good going on the timing!
The coil should not get so hot that it seems to be above the block temp.
A amp reading with the points closed (or the lead to the dist shorted to ground with a jumper) should be 2.5 to 3.5 amps. Toward the low side is best. If more it will shorten the point life and heat the coil. Jim
