1486 hyd problem
Posted by joe 1971 on July 08, 2010 at 13:38:07 from (216.51.206.101):
1486 hydraulics get slow. steering gets slow and brakes get spungy. also 3 point is slow and lifts discbine slow. if i open engine up it helps some. i wouldnt think both pumps went bad at the same time. the mvc pump is only 2 years old. i put air pressure in the trans dipstick tube and held hand over breather to check for leaks and found none. i changed the hyd filter. this tractor had a brand new rear end put in 4 years ago. but the owner had only changed the hyd filter once since then. i did notice a little metal in the filter andv some under the filter on the bottom of the case. new filter didnt seem to help. what do you guys think? thanks. joe
