Posted by Owen Aaland on July 08, 2010 at 18:17:19 from (65.161.86.20):
In Reply to: 1486 hyd problem posted by joe 1971 on July 08, 2010 at 13:38:07:
Does it have enough oil in the transmission. It is possible that the tube for the dipstick has gotten bent down so that even if the level is correct on the stick the tractor is still low on oil. The oil level needs to be at the center of the axles when the dipstick reads full. If you dipstick still has two level marks on it cut it off at the bottom line so that there is only one level mark remaining.
If the oil level is correct, try adding an extra five gallons to cover any possible air leaks inside the tractor. Assuming that you have the earlier style hydraulics, you may have a crack in the super charge line allowing air to enter the suction side of the pumps.
This post was edited by Owen Aaland at 16:29:36 07/09/10.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
