Re: H #64 combine won't start when hot
Posted by Prophetstown on July 09, 2010 at 20:46:57 from (71.98.66.169):
In Reply to: Re: H #64 combine won't start when hot posted by Armand Tatro on July 09, 2010 at 18:44:14:
Thanks Armand and soybeanjoe for the comments. The PTO is not an option since most of the farming is done with horses. The gas tank is above the engine but there is still gas in the carb when this happens. I heard that it was a common problem and you both confirmed that. We have been leaving it run, but as you said a plug, unloader gearbox/belt problem, or such requires a shut-down. Buying a working second unit may be difficult. I will just keep struggling with them for now. Thanks guys!
