On my 350 Utility, the serial number plate is on the right side rather than the left. In the first picture, it would be on the clutch housing just above the flat area, just to the rear of the engine, between the sediment bowl and oil filter dome, and (in this view) obscured by the steel hydraulic lines. As Jim indicated, it could be on the left side -- and it could be covered with grease/dirt wherever it is. If you don't find the plate in either location (Jim's or mine), try cleaning the areas with some lacquer thinner and I'll bet you'll find evidence of four rivet holes that would once have secured the tag. If you can find those holes, at least you'll know you've found the right spot.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
