I can"t recall from memory what the cranking compression should be for 300/350, however 90 is pretty low and 140 seems reasonable. I have never experienced the cam gear jumping a tooth, but I have experienced the cam gear key failing and causing the cam to retard to the point the engine would not run. I had this happen in a 300U and a 450 three different times. Once it starts to go it drops compression and power, and will eventually quit running. I did the same as you, new rings pistons sleeves and bearings with no change, very disappointing. I finally had an old IH mechanic come and check it out when I gave up. He listened to it crank over two times then put his hand over the exhaust manifold and cranked it over until it sucked his hand tight. He then told me that the exhaust should always push, not suck, and to get a new cam, cam gear and key.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
