Re: Farmall 300 gas compression
Posted by D Slater on July 11, 2010 at 17:03:24 from (72.65.150.178):
In Reply to: Farmall 300 gas compression posted by Charles Addison on July 11, 2010 at 09:20:15:
Pressure specs are for a warm engine with all spark plugs removed and throttle wide open, cranking speed at 150 RPM. Before pulling the camshaft it may be a good idea to check valve lift first to make sure thats needed. You also need to remove the oil pan and pump to remove camshaft. If someone already mentioned that I didn't notice.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
