Re: Re: 6 Volt Regulator L post
Posted by Pat on June 05, 2000 at 06:50:47 from (63.227.15.18):
In Reply to: Re: 6 Volt Regulator L post posted by Bob M on June 05, 2000 at 04:49:34:
On the regulator I got from Country General the "L" signified lights. Ran the wire from the "L" terminal to the lights terminal on the switch. My switch is a four position, low charge, high charge, bright lights, dim lights.
Post A Followup
: Re: Re: Re: 6 Volt Regulator L post
