Re: 6 Volt Regulator L post
Posted by Bob M on June 05, 2000 at 04:49:34 from (192.232.120.194):
In Reply to: 6 Volt Regulator L post posted by Barry Fogel on June 05, 2000 at 00:04:03:
third party image
Barry -
This diagram (6 volt, 4-terminal regulator with solenoid in the starter circuit) may be of help. It's for a Super H, but your A will be wired up the same - except possibly for the terminal numbers on the light switch.
Not sure what the "L" signifies on the regulator. I guess it is for LOAD, since that's where the ignition and lighting load connections are made.
To test the ammeter, temporarily wire it in series with a battery and a single headlamp bulb. If the ammeter's working it will indicate the current drawn by the headlamp (3 or 4 amps generally).
Good luck!
Post A Followup
: Re: Re: 6 Volt Regulator L post
