Re: F-12 Type A10 Carb. Fuel Line
Posted by 36F30 on July 12, 2010 at 15:47:33 from (71.214.235.96):
In Reply to: F-12 Type A10 Carb. Fuel Line posted by Bill Copeland on July 12, 2010 at 09:14:45:
Sounds like a heavy or misadjusted float. If the float is good, Try bending the tang to lower the fuel level a bit.
