F-12 Type A10 Carb. Fuel Line
Posted by Bill Copeland on July 12, 2010 at 09:14:45 from (74.126.50.129):
On a gas only F-12 how large should the hole be in the return tee at the gas tank?-- When you split the carb. there is a small brass nipple that fits into a hole in the top part of the carb. Where does this go? and should I be able to blow it out with an air compressor? I have taken 3 carbs. apart and cannot get air thu any of them. Is this just an aglinement pin?
The problem I am trying to solve is too much gas.Neither high or low jet adjustment leans it out at all.
