Posted by jeffalex2 on July 17, 2010 at 03:53:31 from (71.246.72.180):
In Reply to: H battery discharging posted by Drewbee90 on July 16, 2010 at 17:42:50:
Need a little more info...are you running battery or magneto ignition? 6volt or 12volt? Generator or alternator? If you are running factory 6volt set up with a magneto, the most likely culprit is the regulator is defective or wired wrong. Does the ammeter show a discharge when the tractor is shut off?
Also, don't rule out defective battery. I racked my brain for 2 weeks over a bad Napa battery on my Super M. Take the battery out of the tractor and make sure it holds a charge by itself. While disconnecting the battery, take off the negative terminal 1st and try and see if there is a small spark while you remove the terminal, if so, then you have a short in the tractor somewhere.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
