Re: Farmall A Running on Two Cylinders
Posted by El Toro on July 18, 2010 at 04:13:39 from (74.103.74.58):
In Reply to: Farmall A Running on Two Cylinders posted by Rob Flatness on July 17, 2010 at 20:23:50:
Are you sure you have the plug wires in this firing order? Hal
2-1
4-3 As the rotor rotates CW.
PS: Your point gap should be .020" since its been converted.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
