Posted by Rob Flatness on July 17, 2010 at 20:23:50 from (97.195.40.81):
I have an A that was converted to 12 volt before I purchased it a year ago. It got to where it wouldn't start back up after it got hot. It has an H4 magneto so I thought it would be cheaper and easier to convert it to an auto style coil. After wrestling with this all day it started first crank, but is grossly under powered. After pulling the plug wires I discovered that it is only firing on the two middle cylinders. The other two do not have enough juice to arc the spark plug gap. They do have a slight amount if you touch them to the block.
Should I jump right in and replace points, condensor, and distributor cap? Could I have messed up somewhere on my wiring. The coil that I got is a 12 volt and I have a 6v to 12v resistor, but I can't tell you anymore than that. I just bought what the farm store parts guy gave me. Would the coil not be right?
Any help would be great. I have already spent most of my weekly allowance, so think enconomy if possible.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
