Re: Farmall A Running on Two Cylinders
Posted by NawlensGator on July 18, 2010 at 05:55:05 from (68.155.71.134):
In Reply to: Farmall A Running on Two Cylinders posted by Rob Flatness on July 17, 2010 at 20:23:50:
Had to change the plug wires on a 140 that was miss firing on cylinders. I watche at night and it looked like a lightning show.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
