Set the points a little wider than the .013" they are intended to be. .015 will do. Also check to see that the mag cam shaft is not loose side to side. It is important to have a 12v for use with an external resistor coil on it. If the coil is for full 12v it might do what it is doing. Put a different coil on it to see! Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
