The two engines i todown had the same heads but the pistons had a recess in the pistons. You can get hi-dome pistons that are have higher domes than the 8000 ones and use them with no problems at least i havent run into any. The RED POWER ones from my supplier have a much larger dome than the old 8000 ones. You will need a dist so you can adjust the timing so it will start as the mag fires on TJC.There was a directive from IH on that subject.So go ahead and get the hi-dome they will work.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
