IH 484 / D179 PUSHROD PROBLEM
Posted by MRJHG on July 19, 2010 at 05:37:12 from (24.179.63.7):
Problem:
Rear pushrod has broken 3 times.
Motor runs fine for hours until it happens again.
The valves are set right (12).
With valve cover off and engine running everything looks, sounds and feels right.
Lifter appears normal by flashlight.
Recent history:
I have replaced the rocker shaft assembly due to failure of rear mounting stud.
Tractor has not been right since a guy installed my rebuilt injector pump and got the timing way off. It has been corrected since then.
Questions:
Any ideas?
Would I be able to see cam by removing the crank case cover on the side of the block below the exhaust manifold?
What is exact torque of rocker shaft studs?
Please help. I"m getting tired of chasing my tail!
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
