Re: question for tractor vet
Posted by CNKS on July 19, 2010 at 05:56:09 from (216.144.104.128):
In Reply to: Re: question for tractor vet posted by MN Scott on July 18, 2010 at 20:56:37:
I'm not going to dispute what you said, but it sounds like the engine was due for an overhaul, anyway. The temperature gauges on the tractors I drove were pretty accurate. Book says normal operating range is in the center of the green. Many times ours would creep over to the red, and eventually start to blow water out the overflow (pressurized). To prevent that I would have to shift down a gear. My dad emphasized "watch your gauges", so I did. In other words you should be able to monitor the temperature and reduce the load (probably hard to do when grinding feed if you ever want to get done grinding feed). Yes heat caused by overloading can cause a lot of damage, and the use of cheap engine kits probably is partially responsible for the damage. As I implied in an earlier post, it depends on what you are using the tractor for. Probably better off if IH had not used that truck engine. I imagine they saw the coming of more diesel engines and did not want to develop a new gas engine to use only a few years.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
