Is there a part number on the old valves? If you look under "Marketplace" to the upper left of your screen and select "Engine Kits" you will see they ask for this part number.
You could install the new valves in the head with the springs and retainers. Also if you have the new pistons and sleeves installed in the block you could set the head on the block on top of the head gasket. Then install several head bolts or nuts and just snug them so you don't crush the head gasket.
Then adjust the valves to .017" cold then hand crank the engine one complete revolution to see if all the valves clear the pistons. If they clear I would torque the head down then recheck the valve clearance and rotate the engine one more revolution by hand. Hal
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition.
... [Read Article]
Latest Ad:
[More Ads]
