Re: Re: Re: Re: Re: Re: Re: Re: Re: Super M 6v to 12v conversion
Posted by Bob M on June 06, 2000 at 13:10:31 from (192.232.120.194):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: Super M 6v to 12v conversion posted by ltf in nc on June 06, 2000 at 12:47:10:
ltf - I forgot about this: The Ford N series tractors - at least the earlier ones with the distributor in front of the engine - are set up as you describe. They are 6 volt with a resistor to drop to voltage to about 4 volts at the points/coil. There may be others, but I've never run across one. I suspect this was done on the N's to prolong breaker point life since the points are difficult to service on front distributors.
Farmall et al used a 6 volt coil fed direct from the battery - cheap and simple.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Super M 6v to 12v conversion
