Farmall H Generator
Posted by w400 on July 22, 2010 at 21:46:42 from (195.93.21.97):
I replaced the regulator on my H with an OEM part that I managed to track down used the archives here to iliminate all other problems, polarised after fitting and on start up the tractor was charging imeadeatley. Question now is amp meter shows 18amps charge at over half throttle even after an hour of running only drops when you reduce revs increase revs and up goes the charge I no this is normall on start up but after an hour I would have expectecd the charge to go down battery would be quite low also I noticed generator quite hot ie can barley put your hand on it is this normal.Thanks
