Re: Farmall H Generator
Posted by Janicholson on July 23, 2010 at 05:38:23 from (199.17.55.140):
In Reply to: Farmall H Generator posted by w400 on July 22, 2010 at 21:46:42:
Voltage at 3/4 throttle with battery charged: 6v system min 7.1 max 7.3
12v system min 14.2 Max 14.6
If more than these, it will boil the battery dry.
A field wired to ground will do it, as will a bad VR. Jim
