You will be miles ahead if you remove the lower bolster. Support the tractor at the frame rails and you'll be fine. I've had good luck taking a pry bar through the worm gear shaft opening at the front to remove the sector gear. Be aware that the pivot shaft may fall out on it's own if you're able to remove the gear this way.
You may be able to use a block of wood and a large hammer on the shaft to drive it out.
Yes there is a seal at the worm gear shaft. It is part number 43800DA.
You may not have access to this, but I've had great luck driving out the bushing at the worm gear shaft with a piece of 1" copper. A length of 1 1/4" will work for the upper bushing on the pivot shaft. They are the perfect size for both..just small enough to fit into the opening. Take your time removing and installing the seal and bushing on the pivot shaft. It takes some thinking and you may have to come up with a special driver to reinstall the seal on the pivot shaft. Some of the guys here have posted some good examples in the past you may run across.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
