Posted by Dan G on July 25, 2010 at 17:26:41 from (184.8.138.128):
Ok, I've read through the forums extensively about this. So I guess this is revisiting an old topic. Sorry for that!
I've got it mostly apart, but I'm very leary about mushrooming/damaging the top of the shaft that goes down through the bolster. I put a nut on it and took a couple wacks and wow does that seem to be in there. I know I could remove the bolster assy completely and take it to be pressed out but I'd rather not have to do that if I don't have too. I've read where someone welded a rod onto a nut and hit the rod to drive out the shaft. I'm not worried that I have a big enough hammer to get it out, but at what cost? I don't want to damage it. Is there a "best way" to get this thing out?
I've already got the upper and lower bushings, and all the bearings and a new sector gear. This was to fix a wobbly front wheel(s). Also, the grease stains says it was leaking at where the steering worm shaft goes into the sector gear housing towards the rear. Is there a seal there? I didn't see it in the diagram. Oh, and should the lower bolster (where the wheel spindles are) come off in order to remove the bolster shaft? When replacing the sector gear does the worm steering shaft that mates with it need replacement too? Help appreciated. Dan in PA
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
