Re: MD problem identified How to fix
Posted by Jeff Z. on July 26, 2010 at 06:10:42 from (72.228.48.9):
In Reply to: MD problem identified How to fix posted by BruceS. on July 26, 2010 at 05:30:57:
Try some high temp silicone with no gasket.
Put a nice bead on but don't over do it so you don't get excess in the engine.
Put enough on so when it get's compressed it will spread nice and even without voids.
This will help if cover is not true.
Clean both surfaces with some acetone.
