Oh absolutely!!! You can use either an old lawnmower fuel tank (CLEAN IT!) or, in my case, I have a piece of schedule 40 PVC with a cap permanently on one end. The cap has a hole drilled in it and a nipple tapped into the hole with some gasket sealer to keep it from leaking. A rubber gasline and (IMPORTANT) an in-line fuel filter capable of allowing gravity feed (Carquest or an outboard motor filter) are all that is needed after that. I hang it like an IV bottle from the steering column. Put a cap on the top if you are going to test drive unless you like gas on your clothes. Tractor will run great with this setup and you can do all the diagnosing you need. HTH Dave
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
