Re: Janicholson - CUB problems
Posted by 47H on July 26, 2010 at 06:36:21 from (67.63.145.97):
In Reply to: Re: Janicholson - CUB problems posted by Dave H (MI) on July 26, 2010 at 06:16:39:
Okay. The problem is, as I'm sure you are aware, is running the tractor and getting to the generator and voltage reg. at the same time. How did you do this? I suppose you had to fashion some type of fuel tank since the factory tank/hood must be removed to access what needs to be tested.
